Activity Forums AJA Video Systems Audio Popping from Kona 3
  • Audio Popping from Kona 3
    Posted by Bill Paris on July 23, 2008 at 11:26 pm
    Hi Guys,
    I’m getting a popping noise coming from the Kona 3 that disappears when I turn on my HDCAM Deck. I’ve tried disconnecting the audio, SDI, RS422 cables and it still comes through, but when I turn on my HDCAM deck the noise disappears instantly as soon as the deck boots up.
    Has anyone else experienced this issue or know anything about it? For now I’m leaving the deck on to eliminate the popping. Thanks!
    Bill Paris
    Director of Photography
    Crew Hawaii Television
    Mark Maness replied 18 years, 2 months ago 6 Members · 15 Replies
  • 15 Replies
  • Jeremy Garchow
    July 24, 2008 at 12:01 am
    What’s your ref set to?
  • Bill Paris
    July 24, 2008 at 12:21 am
    Jeremy,
    The reference was set to “video in”….. until I changed it to “Reference in” and Presto…. the problem is gone…….. Thanks!
    bp
  • Bob Zelin
    July 24, 2008 at 2:31 am
    damn it ! I wanted to go into my black generator rant !
    GEN10’s should be given out at birth !
    Bob Zelin
  • Arnie Schlissel
    July 24, 2008 at 4:09 pm
    Hey, Bob, have you had a chance to check out the new sync generator from Black Magic Designs? It’s part of their mini converter line: https://www.decklink.com/products/miniconverters/
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jeremy Garchow
    July 24, 2008 at 4:13 pm
    blaspheme…..! ;-D
  • Mark Maness
    July 24, 2008 at 4:28 pm
    I’ve got to find the garlic bulbs for protection….
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    https://blogs.creativecow.net/waynecarey
  • Bill Paris
    July 24, 2008 at 5:31 pm
    Bob,
    Here goes…… I have to ask….. Please give your “Black Generator Rant”.
    I have a sync generator… not the the AJA Gen 10 (It may actually be an older SD Black Burst Generator) …. after reading a couple of posts about sync it seems like I might need one? I’m using the Kona 3 via FCP/Intel MAC with a HDCAM deck and Betacam BVW70.
    Am I suppose to send different types of black burst to the two decks? Does that burst have to match the timing of the timeline I’m working with? 23.98, 29.97, 59.94? I have seen sync issues between the Betacam and the HDCAM deck, but I really only use the Betacam deck for down convert dubs so I could live with it…….. I would rather have everything working together in perfect HD/SD harmony!
    Bill Paris
  • Bob Zelin
    July 25, 2008 at 2:06 am
    I sure did, and it looks great – especially for $295 retail !!!
    The only “problem” is that it cannot do tri level sync and NTSC black at the same time. Many facilities with 2 or more edit rooms need to have BOTH tri level and standard black at the same time (one room doing tri level, one room doing a regular job). So for a “larger” facility, the AJA GEN10 is still the smartest move. But for someone with no money, the Blackmagic is a no brainer.
    I just feel bad for Horita – their days are numbered in this market, unless they drop their price to $150.
    Bob Zelin
  • Bob Zelin
    July 25, 2008 at 2:09 am
    you did not say what HDCam VTR you have. If you do everything at 1080i 29.97 or 59.94, and NEVER EVER use 23.98 (you always do the 2:3 pulldown at the VTR), then you do not need the GEN10.
    HOWEVER, if you work at 23.98, and master back at 23.98, you will ALWAYS be miserable, and your NTSC black gen will do nothing for you. You need SOMEONES tri level sync gen for this.
    With that said, most of my clients never work at 23.98 (always use the pulldown), and only use their old NTSC black gen, with no issues.
    If you have the horrible HDW-M2000 that does not offer 2:3 pulldown as an option, you are screwed, and yes, you will be buying a GEN10.
    bob zelin
  • Bill Paris
    July 25, 2008 at 2:25 am
    Bob,
    I use the HDW-S280 VTR and occasionally would like to work in 23.98. Most of the time I shoot and edit using the F900 at 30psf (29.97) so everything has worked fairly well. I’m a DP and editor so my system is a small stand alone workstation. Do you have any recommendations for a black burst generator that would be appropriate for a system my size?
    Bill Paris
