Activity Forums Apple Final Cut Pro Legacy Audio popping between clips on the timeline
  • Audio popping between clips on the timeline
    Posted by Matthew Hicks on September 16, 2010 at 3:34 pm
    Hi there,
    I’m sure the answer to this question is simple but my Google Fu is failing me today. When I place two clips together in the timeline for a jump cut, there is an audible pop between the clips. It doesn’t seem to matter where the cuts are made.
    I have been working around this by dropping the levels for a fraction of a second at the start and the end of the clips, underlaying ambient audio. But this project is an event with lots of cuts and it’s not very practical.
    Why is this happening, is there something I’m doing wrong and is there an easy fix please?
    – Matthew
    Matthew Hicks replied 15 years, 11 months ago 3 Members · 3 Replies
  • Michael Sacci
    September 16, 2010 at 4:33 pm
    Normal I put to 2 Frame audio dissolve, still a pain but faster that keyframing.
    CORRECTED (had 2 sec by mistake)
  • John Fishback
    September 16, 2010 at 9:27 pm
    Michael’s suggestion will fix your popping. The reason it happens is you’re creating a near-instantaneous change in level from one clip to the next. This in effect creates a vertical ending or leading edge of the waveform and that causes the pop. If you zoom into your sequence tight enough, you’ll see this. Some high-end systems will force what’s called a zero-crossing cut which means the audio is only cut where the waveform crosses the horizontal axis at 0 db. Other systems will automatically apply a short crossfade at every cut (as Michael has suggested).
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Matthew Hicks
    September 17, 2010 at 12:38 am
    Michael, John, thanks for taking the time to reply and explain. Much appreciated. I will use a 2 frame preset audio dissolve from now on, it works a treat.
    – Matthew
