Activity › Forums › Adobe Premiere Pro › Audio point adjustment and 4:3 view on monitor question
  • Audio point adjustment and 4:3 view on monitor question
    Posted by Ken John on June 16, 2008 at 4:36 pm
    Hi, I have two questions that I would reeeally appreciate any help, thank you in advance.
    1. When making only the keyframes and name only appear on an audio file, and then placing a point on the line, and then another point, how do you adjust these so if you want the volume to be raised and then to slowly come down, and then to be raised again? I am using adobe premiere pro 6.5 This was a very easy thing to do on premiere 6.0, but I can’t figure it out here.
    2. I filmed my movie in 4:3, but I started the project as widescreen 16:9. I have edited the same footage before and when I exported it after adding a letterbox, it was fine…16:9, widescreen. But it does not appear this way on the timeline, it shows 4:3 with the black bars on the left and right sides. Is there anyway to change the view so that when I’m editing I see how it’ll look after I export it?
    – Ken
    Ken John replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
