Activity Forums Apple Final Cut Pro Legacy Audio playing out of sync?
  • Audio playing out of sync?
    Posted by Sam White on January 29, 2009 at 9:06 am
    I am running FCP 6 on a dual 2.3 power pc and am having a reoccurring problem with audio. The play head runs through the sequence fine but the audio is always behind or jumping from left side only to right side only. The sequence is synced correctly and you can see that it is visually with the audio waveform. This has recently started happening and I can’t solve it. AHHH
    any Ideas?
    thanks Sam
    Sam White replied 17 years, 8 months ago 3 Members · 5 Replies
  • Bill Dewald
    January 29, 2009 at 9:36 am
    Try a mixdown render (ctrl-apple-r).
    Try quitting FCP, deleting your Audio Renders for the project, and relaunching.
  • Sam White
    January 29, 2009 at 9:54 am
    Thanks Bill,
    I’ll give that a go!
  • Sam White
    January 29, 2009 at 10:52 am
    No Luck. Its a nightmare the play head is always ahead of the actual sound of the audio but the play head is correct in relation to the video. There doesn’t seem to be any audio render files in the project audio render files folder and audio mixdown doesn’t help.
    cheers anyway for your help
    sam
  • Pat Defilippo
    January 29, 2009 at 1:10 pm
    Hi Sam,
    If your sync audio problem appears to be on ALL clips and it appears to be off by just a few frames, try going to Final Cut Pro->System Settings->Playback Controls and taking a look at “Frame Offset”.
    My first guess is that it is on 0 right now on your system. On mine, using an AJA IoLA, I have it on 4 and audio appears pretty well globally synced to video. I seem to recall something like 7 being a popular starting number, and then you can adjust up or down from that. The frame offset varies from suite to suite and it depends on how your suite is wired.
    I hope this does the trick for you,
    -Pat
    G5 Quad 2.5 Desktop with 4GB Ram, 500GB HD & Fiber Card ~
    30″ Cinema Display & 17″ Sony SVGA ~
    Swift Data 200 Internal 1.6TB SATA II RAID 0 ~
    AJA Io LA ~
    Final Cut Studio 2 ~
    Sony UVW-1800 Beta-SP ~
    Sony DSR-40 DVCam ~
    2.33ghz MacBook Pro 17″ (with FCS2) ~~~
    P D Post Productions, Inc. ~
    TV~DVD~VHS~CD~WEB
    for Corporate Communications, Commercials, Infomercials, Television Programs and Family Occasions since 1983 ~
    E-mail PD@PDPost.com ~
    Website http://www.PDPost.com ~
    Business/Cell Phone (847) 275-5671
  • Sam White
    January 29, 2009 at 1:21 pm
    Thanks for reply, i adjusted that but it made it worse then I changed the audio sample rate of the sequence to 44.100 and it fixed it. Thanks for your help though!
    much appreciated
    sam
