Activity Forums Adobe After Effects Audio Playback
  • Audio Playback
    Posted by Robert Till on September 14, 2010 at 4:32 pm
    Hey Everyone,
    I’m having an issue currently that strikes me as a little odd. I’ve been working on a project for a few weeks, swapping out files as need for each new render. I was working on it today, and for some reason it sounds as if my audio is playing back slower than it should be. Not that it is effecting the time, but the pitch is dropped like it’s slowing down.
    I haven’t messed with any frame rates, it just arbitrarily started happening. I’m scrubbing the audio with Command+Drag and even in Audio Preview Ctrl+’.’ I’ve been using mp3s saved from Garageband of some voice over, I know AE usually has issues with compressed audio, but until this moment it hasn’t given me any issues. The frame rate is 29.97 and at RAM Preview it’s playing real time.
    Is this just a glitch or do I need to fix a setting?
    Thanks in advance,
    Rob
    Kevin Monahan replied 16 years ago 3 Members · 6 Replies
  • Robert Till
    September 14, 2010 at 4:34 pm
    Just as another note. The audio in the actual rendered file sounds correct.
  • Robert Till
    September 14, 2010 at 4:53 pm
    Thanks for the rapid response. I gave that a shot, but am still experiencing the slow sound with WAV files. It’s like the pitch got dragged down a bit.
    None of the audio has any effects either, I made sure to check each one.
    Any more advice? The audio isn’t synching, it’s more just BG music and VO. And like I said, the render is fine, but the women sound like men in the previews.
  • Robert Till
    September 14, 2010 at 5:04 pm
    The RAM Preview plays real time, as does the audio preview, they just sound slow. The timing is still correct on the audio though.
  • Robert Till
    September 14, 2010 at 5:30 pm
    And now it’s apparently back to working fine. No idea, I didn’t touch anything for about 20 minutes and it’s stopped doing it. I know it’s not a fixed, so if anyone still has some insight, I’d be glad for the input.
    And thanks for the help Dave.
    Rob
  • Scott Bush
    September 14, 2010 at 6:03 pm
    Not the same issue, but the recent .1 AE update fixed all of the issues I was having with AIFF files (ram previews would be all over the place – I’d preview from the end or middle, but I’d get audio from the beginning).
    Worth an update if you haven’t already anyway.
  • Kevin Monahan
    September 14, 2010 at 10:44 pm
    Right! A lot fixes in the latest update. Check it out if you already have not done so.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
