A few things to check:
Do you get audio at the Finder/OS level? or no audio at all?
Are you using a I/O card like Blackmagic or AJA? If so, your audio may be routed out from the I/O card and not your Mac system audio. Check your Project settings.
Make sure your volume is up.
Make sure you are not muted.
Go into your system prefs, click sound, and click the output tab. make sure the device you want is selected and the the volume is up.
Make sure your speakers are on and connected to the output source.
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
Hear me pontificate: Speaking Schedule .
