Activity Forums VEGAS Pro Audio peaks rebuild with drag/drop concurrent projects
  • Audio peaks rebuild with drag/drop concurrent projects
    Posted by Jim Greene on March 30, 2011 at 12:31 pm
    This is a problem I’ve seen for years with probably all versions of Vegas, and now with Vegas Pro 10. I have some very large audio files, like 3 hours in mp3 format. I have two Vegas projects open. I drag the mp3 to project 1 and the audio peaks are built. So now I have a .sfk file for this. Then I drag the same mp3 file to project 2. The audio is built again. Why?
    This drives me crazy. I need to wait for several minutes sometimes, even after I just waited for the peaks to be built in project 1. I have found an anomaly, in that if I save/close project 2 then reopen it and drag the file, the peak file isn’t rebuilt. Not a great solution.
    Jim Greene replied 15 years, 5 months ago 2 Members · 4 Replies
  • John Rofrano
    March 30, 2011 at 12:36 pm
    [Jim Greene] “I have found an anomaly, in that if I save/close project 2 then reopen it and drag the file, the peak file isn’t rebuilt. Not a great solution.”
    It sounds like maybe Vegas is taking a snapshot of the files in that folder and it isn’t seeing that you built the peaks already. Try pressing the refresh button in the Vegas explorer of the second project before dropping the file into it and see if that helps. (just a guess)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Greene
    March 30, 2011 at 12:55 pm
    Thanks, I never use the the explorer in Vegas, I always use Windows Explorer to drag files. But I just tried it and it didn’t make any difference.
    However, I have found the reason it happens. I normally use the preference to *not* “close media files when not the active application”, that is, this option is unchecked in preferences. So it seems that any other Vegas instance can not see the .sfk file if the associated media file has an open Windows handle. That’s too bad, as the preference to keep file handles allows me to switch back and forth between projects without much reloading delay. I always edit with two projects open, especially to help synchronize portions using PluralEyes, or to use as an event trimmer since the one in Vegas is always Full Resolution and basically useless for h.264 files.
    -Jim.
  • John Rofrano
    March 30, 2011 at 2:10 pm
    Great detective work! 🙂 If you usually keep two projects open at once, you really should allow Vegas to close media files so that you can edit them with other applications and Vegas will refresh with the changes.
    ~jr
  • Jim Greene
    March 30, 2011 at 3:53 pm
    Yes, I like the feature of editing outside of Vegas and having it pick up those changes, I do that often. But I simply set the preference temporarily then set it back to keep files open so I can switch between projects faster.
    As for the Windows handles, I was trying to logically determine the cause as it made no sense. Then my 20 years of computer software development kicked in and I thought of the answer. It’s still strange behavior, and really a small bug, because if I shut down both projects then open them again, project 2 doesn’t need to rebuild the peaks — it’s just an anomaly when the project that first built it doesn’t allow the 2nd to see the peak file until the first project closes the file handle of the event. And the peak file isn’t locked during this period because project 2 will overwrite it. Just the event file is locked. Weird.
    -Jim.
