Activity Forums Adobe Audition Audio peak – 12db or -6db
  • Audio peak – 12db or -6db
    Posted by Alex Rinquest on October 2, 2007 at 2:54 pm
    This may be a dumb question but after delivering pgms with audio peaking -12db we’re faced with a request for audio content to be delivered at -6db.
    Could you pse verify what it should be?
    Many thanks
    Alex
    Emmett Andrews replied 18 years, 10 months ago 3 Members · 2 Replies
  • Willie Toth
    October 2, 2007 at 3:21 pm
    -6db is industry standard … I would use the hardlimit function depending on the gain of your file amplify by 1 to 6 db with a peak limit of -6db …….. WILLIE
  • Emmett Andrews
    October 2, 2007 at 5:08 pm
    You can run it to 0dBFS without distortion. Deliver at whatever is asked for by the client. If the client has no preference and it’s a final mix, send it at -0.1dB. Peak values don’t really influence RMS levels, so it has nothing to do with loudness. 0dBFS (or -.1) will give you the best S/N ratio.
    Emmett
