Activity Forums Apple Final Cut Pro Legacy audio panning
  • Posted by Perri Frank on February 20, 2007 at 7:03 pm
    I am currently trying to export a quicktime with dialogue on channel 1 and music and effects on channel 2.
    I’ve set my sequence setting to dual mono and assigned my 8 track audio edit to appropriate channel 1 or 2
    when i playback the seq it still comes out stereo.
    my seq setting is dvntsc 48k my quicktime will be same as source.
    i’ve also selected in settings, audio settings config. channel grouped
    I even tried restarting.
    is there something else that i am missing?
    Jon Fawcett replied 14 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    February 20, 2007 at 8:20 pm
    What Dave says or continue down the path that you started (with the dual mono) then you have to control click on the front of each audio track and assign each track to whatever output channel. For example, control click next to the little auto select box in the A1 track. You will see a little drop down menu that says audio outputs. Select 1 for track A1, and then repeat except choose 2 for track A2. Make sense?
    Jeremy
  • Perri Frank
    February 20, 2007 at 8:31 pm
    I just figured it out. I had assigned all the tracks to the correct channel i wanted it to hear it on but i was still hearing it on both channels.
    I had to go into the audio mixtool and click off downmix, which someone before me had selected.
  • Jeremy Garchow
    February 20, 2007 at 8:41 pm
    Downmix is usually on by default. I forgot about that part. Good catch.
    Jeremy
  • Andy Mees
    February 21, 2007 at 3:56 am
    fwiw QT Player doesn’t read the exported movie’s dual mono status anyway … so your movie will still play back as full mix after you’ve exported it (although it will be correctly interpreted if you reimport to fcp)
    if you paln on playing the movie back and want to have discreet audio you have to set your sequence settings to stereo and use the pan controls to provie the separation. (tracks assigned to ch1 you should pan left, tracks assigned to ch2 you should pan right)
  • Perri Frank
    February 21, 2007 at 8:08 pm
    I was able to export the qt through compressor and get the audio on the desired channels.
  • Andy Mees
    February 22, 2007 at 1:32 pm
    good to know. thanks.
  • Jon Fawcett
    November 7, 2011 at 10:27 pm
    This is really helpful – I have a very similar issue but having followed this workflow I get to a point where I have separate tracks, but I can still hear a little of each one in the other – any ideas? I really need clean signal for each track…
