Activity Forums Apple Final Cut Pro Legacy audio panning left right
  • audio panning left right
    Posted by David Lewis on July 19, 2011 at 7:13 am
    I need to split my audio tracks. I need VO/SYNC/FX on CH1 and Music on CH2.
    Since the music is stereo, I am having trouble trying to make it “mono”, and get it to CH2. When I use the Pan option, is simply splits the two channels L/R. I cannot eliminate the bleed of music onto CH1.
    Now, if I try and delete one music channel (I only need this for reference… doesn’t need to be stereo), I can’t… I end up erasing the 2nd channel as well.
    Must be a simple fix I’m missing… what is it??
    David C. Lewis
    Editor- Director
    DCL Video Productions
    David Lewis replied 15 years, 2 months ago 1 Member · 2 Replies
  • David Lewis
    July 19, 2011 at 7:01 pm
    Hi Dave:
    Thanks for your answer… I figured it was something simple like that (in AVID, which is where I am more comfortable, I’ve been able to do that without any problem).
    My only question is, where/what do click to dis-engage the stereo option? I’ve been playing around abit with the Audio Mixer and I don’t find that option.
    Sorry for the “spoon feed”, but I haven’t found an answer by my own devices of “trial and error”.
    In the end, which actually made my editing easier in this particular instance for what I needed to do, I made a VO/SYNC/FX track (eliminated all the music) and exported it as a mixed QT movie. I did the same for the stand-alone scratch music. I then placed imported these new audio files, placed them into the timeline matiching the video. THEN I was able to very easily pan the tracks L/R for CH1/2, as there were no longer any stereo associatd tracks.
    Thank you for your help.
    David C. Lewis
    Editor- Director
  • David Lewis
    July 20, 2011 at 5:41 am
    Hi David:
    I found it and (of course) it works perfectly. Thanks for guiding me through that. For some reason I didn’t see that line in the drop-down menu (guess I “didn’t look hard enough”… as I’m oft to remind my daughter to do!).
    As I work more and more with FCP I’m finding it very easy and friendly to use… the trick is just to get over the learning-curve and get to know the system… of course just when I’m getting to be somewhat “proficient” (still got a ways to go)… they drop FCP7 and promote FCPX, which apparently is missing a few key features I may need.
    All the best and thanks again!
    David C. Lewis
    Editor- Director
