Activity Forums Adobe Premiere Pro audio pan error importing xml fcp in adobe premiere
  • audio pan error importing xml fcp in adobe premiere
    Posted by Calixte Govaarts on June 19, 2014 at 8:34 pm
    When I import xml from fcp 7.0 in adobe premiere my audio is al wrong. al the left channels are allright but all the right channels playing not only the right channel but also a left channel as if it is stereo. When I replace the clip with the orignal clip its oke but that’s a lot of work with long sequences from older projects. Does anybody know the solution. I tried to export with 2 stereopairs, dualmono but it all don’t works.
    kliko
    Peter Garaway replied 12 years, 3 months ago 2 Members · 2 Replies
  • Calixte Govaarts
    June 20, 2014 at 12:14 pm
    anybody has an answer?
    kliko
  • Peter Garaway
    June 20, 2014 at 4:46 pm
    Hi kliko,
    This doesn’t sound right. Can you upload your FCP project file so I can take a look at how your mapping was done?
    Peter Garaway
    Adobe
    Premiere Pro
