Activity › Forums › AJA Video Systems › audio output trouble
  • Jeremy Garchow
    August 16, 2005 at 12:54 am
    Delete your audio render files, then select all of your clips in the timeline and do an audio mixdown. if that doesn’t work, enable and reenable the clip that the drop out happens. This should shake loose any weird render files. An offending render file is what I suspect is causing this behavior.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
