Audio output to Digibeta SDI 16 bits or 24 bits?
Decklink Extreme, FCP 5, OX X.latest.. g5 dual 2.
Should I mix to 24 bit audio or 16 bit audio for the best results mastering out of Decklink. In theory the 24 bit mix is better but will my setup output it in a way that preserves the quality? FCP can play back the 24 bit audio.. but does it down sample it first? Does it add dither? Digibeta is 20 bits. Do I apply a 20 bit dither to the 24 bit mix? What about a 16 bit mix? where is it getting the extra bits to bring it up to twenty? In FCP? Or is the Decklink card doing it? Is it being dithered? Is the decklink card 24 bits internally? etc. etc.
Anyone from Blackmagic want to answer? I’ve posted these questions a couple of times… some say that audio really is black magic..
Thanks for the help.
Jason Levy
