Activity Forums Apple Final Cut Pro Legacy Audio Output to Beta Sp
  • Audio Output to Beta Sp
    Posted by Xtothed on February 10, 2006 at 5:47 pm
    Hi all,
    I have two queries…that in some ways are related.
    I have edited and dumped down a TV commerical onto Beta SP, PAL 16:9 – via Final Cut Pro, Blackmagic Decklink and into the UWP 1800.
    My audio levels in FCP are set to – 18db. That is for the bars and tone, as well as the commercial peaking at just over this level as well. I then set this level upto 4 on my PPMs and into the Beta Recorder. It does look a low on the Beta’s levels and I have had complaints about the level being low on the tape. Am I doing all of this correctly? How can I assure that the -18db in Final Cut is -18bd on the tape.
    Secondly – the tech report – I have a tech reports with aspect ratio, programme codes, audio levels etc. – which I fill out accordingly. But I obviously I am not sure that what I am putting, in regard the audio especially, is correct. On top of this, in order for the commercial to be broadcast, I transfer the Beta SP to Digi Beta with another company. They are acting as the quality control at the moment (with regards the sound) but obviously I want to make sure I am giving them the right information and content on the tape.
    Hope someone can help – I will also post this in the Blackmagic and Broadcast Video forums.
    Thank you.
    Xavier
    Frank Nolan replied 20 years, 7 months ago 2 Members · 1 Reply
  • Frank Nolan
    February 10, 2006 at 6:02 pm
    [xtothed] “How can I assure that the -18db in Final Cut is -18bd on the tape.”
    You do not want -18db to be -18db on a beta sp tape. That’s why your levels are low on tape. The meters in FCP are digital and beta sp is analog. The setting should be a tone of -20dbfs (db full scale) = 0db on beta sp.
