Activity Forums Adobe After Effects Audio Output Probs
  • Audio Output Probs
    Posted by Chris Newton on July 13, 2006 at 11:12 am
    Does anyone know why I keep getting a ‘Error opening sound component’ intermitantly when (a) ram previewing and most annoyingly (b) when trying to render a wav out of After Effects.
    All clips have been imported as 16bit 48Khz and my preview settings in After Effects are set to the same specs.
    As I say the error is intermitant. If I persist in exporting a wav from the timeline eventually it works.
    Is there something I am doing wrong? I don’t usually use after effects to put an audio edit together but I needed to time up the sound fx to the animation I was making and did not want to recreate it in Premiere or Pro Tools.
    Here is a list of my setup.
    PC runnning Windows 2000, After Effects 6.0 and Quicktime 7.0.2
    Thanks A lot
    Regards
    Chris
    Chris Newton replied 20 years, 1 month ago 2 Members · 2 Replies
  • Tim Kurkoski
    July 13, 2006 at 8:27 pm
    Upgrade to the newest version of QuickTime. This was a known problem with QT 7.0.2.
  • Chris Newton
    July 26, 2006 at 10:09 am
    Hi Timothy,
    I have upgraded to the latest version of quicktime (v7.1) and am still getting the same error on render. Could it be that I need to upgrade to quicktime pro? I don’t see why.
    If you have any ideas it would be much appreciated.
    Thanks a lot
    Kind Regards
    Chris
