Activity Forums Broadcasting audio output from DSR-1500A
  • audio output from DSR-1500A
    Posted by Melissa on April 14, 2005 at 7:13 pm
    Hello
    I am using the DSR-1500A a DV cam deck to capture media onto my computer. I can’t adjust the audio output levels for some reason, and they are just a little low. I realize it’s probably a simple setting in the menu but I cant seem to find it. Any one know what to do?
    Thanks!!!
    Melissa
    David Jones replied 21 years, 5 months ago 2 Members · 1 Reply
  • David Jones
    April 15, 2005 at 2:58 pm
    Sounds like you are doing a digital transfer.
    In order to adjust the audio levels upon transfer,
    you will need to use the analog audio outputs from the deck.
