Activity › Forums › Apple Final Cut Pro Legacy › audio output
audio output
Posted by Dennis Allen on August 15, 2005 at 10:13 pmaudio output cuts out at same place everytime I edit to tape. Any help appreciated.
Thaxter Clavemarlton replied 21 years, 1 month ago 2 Members · 1 Reply -
1 Reply
August 15, 2005 at 10:32 pmThere is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs or freezes.
NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
Sequence Menu > Render Only > Mixdown.
You should see a dialog box telling you its rendering.
It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
