Activity Forums Media 100 Audio out
  • Audio out
    Posted by Frank Cann on August 7, 2009 at 6:30 pm
    I know there has to be a better way…
    With my Media 100 audio set at 44100 Hz – its way too strong of a signal for my analog DVD-R machine. To overcome this I have been dropping the bus to about -17 db.
    Is there something I should be doing different?
    Floh Peters replied 17 years, 1 month ago 2 Members · 3 Replies
  • Floh Peters
    August 7, 2009 at 9:33 pm
    Which system? How is your analog audio set up? Which connections? And why are you using 44.1???
  • Frank Cann
    August 10, 2009 at 1:16 pm
    Sorry about that –
    System M100 Suite V 1 (Intell)
    Source In – Analog – using XLR cables
    Convert to 44100 Hz
    Output Kona HHe
    Rate 48000 HZ
    Sync audio to analog
  • Floh Peters
    August 10, 2009 at 2:58 pm
    So I guess you are using a Kona LHe? Look in the Audio out prefefences for the analog audio level selection and set it to a value that works with your DVD recorder…
