Activity › Forums › Adobe Premiere Pro › Audio out off sync
Volodymyr Kashuba
September 12, 2011 at 6:14 pmHi Jeff,
Thank you for helping with this issue.
I am using Matrox MXO2 Mini with MAX for almost 2(two) years now and never had this problem before. Audio conected to monitor thru RCA cabele, not HDMI. And import i did this same way i did for last 10 years. The problem started to apeer on lest few projects. I will check all the options you suggest, but I don’t think this is the problem, becouse audio out-of-synk not only on prewiewing monitor, also in Premiere too, and on my new project. Audio in the project editet in February is in sync and there is no changes in footage, Premiere settings or Matrox settings.Windows 7 Ultimate 64bit,
Intel Core i7-2600K Sandy Bridge 3.4GHz (overclocked to 4.5GHz),
CORSAIR CWCH50-1 High Performance CPU Cooler, ASUS P8P67 PRO,
G.SKILL Ripjaws X Series 16GB,
EVGA GeForce GTX 460 (Fermi) 2GB ,
Matrox MXO2 with MAX,
COOLER MASTER HAF 932 Black ATX Full Tower Computer Case,
Adobe CS 5 Production Premium -
Ann Bens
September 12, 2011 at 8:43 pmIs the audio OOS in a non Matrox environment?
Adobe Certified Expert Premiere Pro -
Volodymyr Kashuba
September 12, 2011 at 9:46 pmSorry, What mean OOS.
Ann Bens
September 12, 2011 at 11:43 pmSorry: Out Off Sync.
Volodymyr Kashuba
September 13, 2011 at 12:59 amYes, in some of my posts above I said that in NON Matrox project audio is out-of-sync too.
Daniel Campbell
December 1, 2012 at 2:07 amDid nobody ever figure out a fix for this? I’ve actually run into it a few times in Premier Pro now. Not sure if it makes a difference, but I’ve only been having this issues with importing MP4 files from a Hauppauge DVR.
Volodymyr Kashuba
December 2, 2012 at 9:22 pmI turned off pre-record function on my Panasonic AG-HMC150, and now I never have a problem with audio out off sync on timeline. I do not know if this has someting to do with audio out off sync, but I stop having this problem.
Jayson Valencia
May 9, 2013 at 5:48 pmShot 1080i footage for music video.
Playback from a CD player for artist.Using After Effects to edit full blast HD final.
I have 44khz audio file imported to use.Comp is NTSC 29.97….right???
Do I have to upsample to 48khz? If 44khz is recorded on to 48khz video camera, do I have to change the 44khz file in the Comp to sync???Please help fast,
Jay Valencia
Iain Clark
August 3, 2013 at 11:21 amI had the same problem. I’ve managed to get around it by re-encoding the files using an H.264 encoder such as Handbrake, before taking into Premiere Pro. Footage works a dream now.
