Activity Forums DaVinci Resolve Audio out of synch
  • Audio out of synch
    Posted by Bruce Gaber on May 23, 2019 at 6:14 pm
    Just shot some iPhone footage and it plays back fine on the iPhone. But when I bring it into DR, the audio is way out of synch. I shoot at 30 fps and set up the project settings accordingly. DR did not report a frame rate mismatch on import. The problem persists in both the Cut and Edit modes.
    Set-up: iPhone 7, Rode VideoMic Me-L, MoviePro set to 30 fps, 48KHz, H.265, AAC
    Any ideas on what’s going on here?
    Thanks as always
    Bruce
    Bruce Paul Gaber
    DR 16.0.0B.017
    macOS Mojave 10.14.4
    iMac 27″ 2019
    3.6 GHz Intel Core i9
    40 GB 2667 MHz DDR4
    Radeon Pro Vega 48 8 GB
    Marc Wielage replied 7 years, 3 months ago 4 Members · 6 Replies
  • Ole Kristiansen
    May 23, 2019 at 6:56 pm
    Hi
    Try opening one of your recordings in the QuickTime Player and save your recording again – then try opening the recording into the Davinci Resolve !
    Best,
    Ole
  • Bruce Gaber
    May 23, 2019 at 7:19 pm
    Hi Ole
    Thanks. Interesting idea, but it didn’t work. I tried to relink the footage after the save from QT and also just deleted it from DR and reloaded it. No deal.
    What do you think is going here?
    Bruce
    Bruce Gaber
    OSX High Sierra 10.13.3
    iMac 27\” late 2013
    3.5 GHz Intel Core i7
    24 GB 1600 MHz DDR3
    NVIDIA GeForce GTX 780M 4 GB
    DR 14.33.0.014
    AE 15.0.0
    vimeo.com/BodhiBruce
    visionrising.com
    Dance Without Reason
  • Ole Kristiansen
    May 23, 2019 at 7:37 pm
    I can see that you have set MoviePro to 30 fps – but I still think your recordings are with variable fps! You can try converting a recording to constant fps, with HandBrake! Or use the MediaInfo app – to view data of your recordings!
  • George Dean
    May 23, 2019 at 10:05 pm
    Bruce, I would agree with Ole, transcode to get constant frame rate. But if that doesn’t help you may also want to download and install the latest v16b3.
    Best Regards……George
  • Bruce Gaber
    May 23, 2019 at 11:36 pm
    Thanks Ole
    Whatever was wrong, HandBrake fixed it. Thanks so much
    Bruce
    Bruce Gaber
    iMac 27\” late 2013
    24 GB 1600 MHz DDR3
    DR 14.33.0.014
    AE 15.0.0
    visionrising.com
  • Marc Wielage
    May 25, 2019 at 2:25 am
    My opinion is that iPhones are bad choices for video cameras. You’re better off getting a real video camera (even something modest like a 5D or 7D DSLR, or perhaps a low-cost BMD camera) and then degrading it to make it “look” like a cell phone camera. You can always add an iPhone overlay to make it look like a phone — I’ve done that several times in indie films.
