Activity Forums Apple Final Cut Pro Legacy Audio out of sync when exported to QUICKTIME
  • Audio out of sync when exported to QUICKTIME
    Posted by Jim Carswell on March 10, 2013 at 10:24 pm
    Hello,
    I am editing on Final Cut 7, Mac Pro, eSata Cal Digital drives, Kona 3 card.
    Been editing for years- but this is my first project with DSLR video. I brought the footage in as ProRes 422. It is 1920×1080 23.98 from a Canon 7d. Audio was recorded separately on a Tascam DR680.
    The audio in my timeline is in perfect sync with the video. However, when I export a QUICKTIME movie utilizing current settings- the audio winds up slightly out of out of sync ( a few frames).
    This has happened every time I try to export the timeline (20 minutes).
    Any thoughts or ideas what might be causing the sync problem upon export? Your help is appreciated.
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
    Jim Carswell replied 13 years, 5 months ago 2 Members · 3 Replies
  • Jim Carswell
    March 12, 2013 at 3:14 am
    Solved the issue.
    Jim
    Jim Carswell
    Savannah, GA
  • Daniel Sametz
    March 12, 2013 at 3:35 am
    Hi, Jim:
    How did you fix it?
    what was wrong with it?
    Greetings.
    Daniel.
  • Jim Carswell
    March 12, 2013 at 6:31 pm
    I made the mistake of setting up my timeline sequence as AJA Kona3 1080p23.98 instead of Apple ProRes 422 1920×1080 24p. Once I created the proper sequence and copied and pasted my timeline into this new sequence and rendered- everything was in sync upon exporting a QUICKTIME.
    Jim
    Jim Carswell
    Savannah, GA
