Activity › Forums › Adobe Premiere Pro › Audio out of Sync on XF105 on Mac
  • Audio out of Sync on XF105 on Mac
    Posted by Craig Shields on February 3, 2012 at 8:44 pm
    I have been searching for an answer for this without success. We have a new XF105. I recommended PPCS5.5 because it’s supposed to natively handle this footage. I copied the whole contents folder from my CF card to my hard drive. When I imported into Premiere, most of the footage went out of sync. At first I thought it was the camera but when I opened it in the Log & Transfer window in FCP7, it was all in sync. What is happening on PP’s end. I need this to work without some crazy work around.
    Thanks.
    Premiere Pro CS5.5.2
    MacBook Pro
    Paul Neumann replied 14 years, 7 months ago 2 Members · 1 Reply
  • Paul Neumann
    February 4, 2012 at 5:13 am
    Wow! I run that same set-up though with the XF100. Never had a sync problem. I almost always shoot 1080/60i/35mbps. Edit with CS5.5 (and sometimes FCPX) on a i7 quadcore macbook. Simple firewire 800 drive.
    How long into a clip before you see the sync’s gone bad?
