Activity Forums Apple Final Cut Pro Legacy audio out of sync in timeline issue
  • audio out of sync in timeline issue
    Posted by Bartek Zee on July 26, 2012 at 11:28 am
    Hi there,
    I am putting some voice-over to a film and the .wav file (48khz 16bit) goes out of sync in the timeline, that is, the waveforms are in one place but the actual audio starts about 15 frames earlier. What should be silence has a syllable of sound! Very tedious to cut and fine tune when you use the waveform … My timeline is set to the same specs accept for the 32 bit floating point(which I am told doesn’t affect sync). I tried converting my wave to an aiff but same problem. ug!
    thanks y’all for any clues,
    Macbook pro 4.1 duocore, 2.5 ghz, 4GB ram
    OS 10.6.8
    FCP 7.0.3
    Bartek Zee replied 14 years, 1 month ago 1 Member · 1 Reply
