Activity Forums VEGAS Pro Audio out of sync in preview
  • Audio out of sync in preview
    Posted by Scott Francis on February 2, 2011 at 12:32 am
    Hey All,
    Just upgraded to Vegas 10 this month and love it. I am at times having issues with the audio being out of sync in preview window even when I have only a few audio effects on. I have an AMD Phenom II X6 1090t and plenty of ram (8 gig) in a WIndows 7 Ultimate 64 bit environment. I am using Waves 7 plugins for audio and NewBlue FX for video. It is only one stream of video SD widescreen with one video plugin and pan crop to match output aspect.
    When I stabilized a clip, the audio is WAY out from that clip.
    Anyone else have this issue or know any way to fix it?
    I use a TON of audio effects when I do concerts and this will really be an issue coming up…
    Thanks for any help!!
    Scott Francis
    Mind’s Eye Audio/Video Productions
    Scott Francis replied 15 years, 7 months ago 2 Members · 2 Replies
  • John Rofrano
    February 2, 2011 at 1:56 am
    Is the audio in sync when you render? It could be just a preview problem. Is the audio lagging or is the video lagging?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Scott Francis
    February 2, 2011 at 3:25 am
    Video is lagging….it did it before (another project) as well with audio…I switched to “microsoft mapper” in the audio device settings and it took care of it. This time it was already set to that, so I switch to the Firestudio (I have a Presonus Firestudio 26×26 I use) and still had the lag. I have not tried to render either one with the lag because the FX were not necessary so I removed them. Just want to get all correct before I have a big project with an audio mix as well and this happens.
    I THINK it is just a preview problem, but even when I switch it to “draft” it still had the lad issue…very odd…
    Scott Francis
