Activity › Forums › Audio › audio out of sync after exporting to h.264 mov file
  • audio out of sync after exporting to h.264 mov file
    Posted by Tristan Wira on December 4, 2008 at 4:46 pm
    hi guys just a quick question
    i have some problems with the sync of audio and video
    in the edit everything is 100% on sync
    only when exporting it sseems that the further the playback of the clip progresses the more the audio gets out of sync
    the audio source i imported in adobe cs3 premiere pro it’s sample rate is 44.1 khz
    could that be causing my problems? do i need to import an acceptable audio file into premiere pro cs3 with a sample rate of 48khz to solve my problem?
    tnx for you much needed advice…much appreciated!
    Tristan Wira replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
