Activity › Forums › Apple Final Cut Pro Legacy › audio out of sync
  • audio out of sync
    Posted by Michelle on November 1, 2005 at 4:57 pm
    We have captured uncompressed SDI DVCpro video to our XRAID. We are running FCP 5.0.2, OS 10.4, XSAN 1.1.
    It seems as if our audio is lagging behind the video when we are playing it back. The partition is striped raid 5 and we only have 2 streams playing, so speed should not be an issue. I can make the audio speed up by checking the 12 tracks of audio mixing, and i can make it slow down by checking 32 or 64 tracks of audio mixing (I only need 8). This is a 45 minute project that we brought in just to lay graphics on. Are there any other settings that need to be checked? We have also mixed down the audio and had no luck.
    Any help is appreciated.
    Thanx much,
    M
    M
    Walter Biscardi replied 20 years, 11 months ago 5 Members · 6 Replies
  • Peter Ralph
    November 1, 2005 at 5:11 pm
    how are you monitoring picture and sound?
  • Michelle Harvey
    November 1, 2005 at 5:34 pm
    On the canvas with built-in audio checked
  • Michelle Harvey
    November 1, 2005 at 5:38 pm
    We are monitoring on the canvas with buit-in audio selected
  • Dcsillag
    November 1, 2005 at 10:14 pm
    It’s a known problem with DVCpro and FCP 5. It’s a non-issue in FCP 4.5 and earlier.
    Apple says it’s working on the problem, but is mum on a fix.
  • Walter Biscardi
    November 1, 2005 at 11:08 pm
    You can play with the Playback Offset to adjust the playback into sync.
    Whenever working in FCP I only monitor my external NTSC monitor and my external speakers via a Kona 2 with Playback offset set to 0.
    Walter Biscardi, Jr.
    Now editing “Good Eats” in HD for the Food Network
  • Walter Biscardi
    November 1, 2005 at 11:09 pm
    [DCsillag] “It’s a known problem with DVCpro and FCP 5”
    I’ve only heard of DVCPro HD 720p having issues with SDI capture. This is the first I’ve heard of SD DVCPro material having an SDI issue.
