Activity › Forums › VEGAS Pro › audio only
  • audio only
    Posted by The Kiwi on December 18, 2005 at 5:31 am
    I have been finding that sometimes when I add or attempt to add video to the time line in vegas only the the audio track shows up no video finding this is happening mostly with some of my avi files how can I correct this problem??
    Edward Troxel replied 20 years, 9 months ago 2 Members · 3 Replies
  • Edward Troxel
    December 18, 2005 at 5:39 am
    Install whatever codec is required for those AVI files. Where did those AVI files come from?
    For example, many still cameras will take an AVI file. However, most of them require an MJPEG codec in order to see the video.
    Edward Troxel
    JETDV Scripts
  • The Kiwi
    December 18, 2005 at 11:31 am
    thanks for your reply
    It isn’t codec issue as the files play in either windows media player realplayer or winamp.
    They are older files I can work around by converting them to either wmv or divx or mpeg.
    They will then import into the video and audio timelines then.
  • Edward Troxel
    December 18, 2005 at 12:48 pm
    Yes it IS a codec issue. In the case I mentioned, those files will ALSO play in WMP but will not appear in Vegas until the MJPEG codec is installed. Use gSpot to figure out what the codec required really is and then install that codec.
    Edward Troxel
    JETDV Scripts
