Activity Forums VEGAS Pro audio only on one channel
  • Don Smith
    July 24, 2008 at 3:22 pm
    Never mind. Duh, should have checked the help file before posting. All fixed. Easy fix, just select edit/channels/combine.
  • John Rofrano
    July 24, 2008 at 4:34 pm
    Actually, that just masks the real problem which is that you recorded a mono source as stereo. What you should do next time is when you record, after you arming the track, go to the record input selector and select Left (Mono) and record as mono. This is the correct way to record mono signals and won’t require any combining of channels.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
