Activity Forums Apple Final Cut Pro Audio only cross fades
  • Audio only cross fades
    Posted by Shelley O’neil on October 20, 2013 at 6:45 am
    I want to be able to drag and drop audio only cross fades in fcpx.
    Is it possible?
    A four frame (sometimes 2 frame) cross fade was one of my most used favourites in FCP 7.
    Is it possible to do in FCPX without labouring away in the trimmer manually adjusting fade handles on every edit. I need to apply a 4 frame audio-only cross fade on hundreds on edits.
    Cheers,
    Shelley
    John Fishback
    replied 12 years, 11 months ago
    5 Members · 4 Replies
  • James Cude
    October 20, 2013 at 7:29 am
    Not like you could in 7- here are some workflows:
    https://www.larryjordan.biz/a-better-way-to-do-audio-transitions-in-fcp-x/
  • Jari Innanen
    October 20, 2013 at 9:20 am
    There is an audio only dissolve plugin from Alex 4D:
    https://www.youtube.com/watch?v=PepLyRKogmE
  • James Ewart
    October 21, 2013 at 11:19 am
    Nice thanks fort this.
    The Apple plan for FCPX becomes clearer and more apple like every day.
  • John Fishback
    October 21, 2013 at 6:19 pm
    i Use Alex4D’s audio-only cross-dissolve all the time.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
