Activity Forums Apple Final Cut Pro audio only auditions?
  • audio only auditions?
    Posted by Larry Watts on December 4, 2017 at 11:31 pm
    I need to replace the audio in a group of interviews after creating new audio only clips from isotope RX6.
    Ideally I’d like to drag the audio file onto the existing audio and create an audition. This is not working for me.
    Is it possible?
    The other route is to make new sync clips, but I loose my color correction and keying and other things. I tried it and it takes too long.
    A second question is: can I attach the audio once I’ve manually synced the clips so it doesn’t get bumped by mistake.
    Kind of like a connected clip only audio. Then I’d mute the existing audio.
    THX Larry
    Larry Watts replied 8 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
