Activity Forums Adobe Premiere Pro Audio on Timeline and Preview DVD; not on final DVD
  • Audio on Timeline and Preview DVD; not on final DVD
    Posted by Douglas Fraze on May 30, 2009 at 4:00 pm
    I have placed voice remarks, sound effects, voice remarks from digital recorder, and music on my Timeline. All sounds are present when I play the Timeline; all sounds are present when I preview DVD within DVD Layout. When I burn the DVD I do not have sound. Why? How do I correct this problem?
    Doug Fraze
    Eddie Lotter replied 17 years, 3 months ago 2 Members · 5 Replies
  • Eddie Lotter
    May 31, 2009 at 4:56 am
    I’m guessing you are not multiplexing and getting separate audio and video files.
    See FAQ:Why is there no audio in my exported MPEG file?
    You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
  • Douglas Fraze
    May 31, 2009 at 5:04 pm
    OK, what is multiplexing? Didn’t see any mention of multiplexing in my Classroom in a Book.
  • Eddie Lotter
    June 1, 2009 at 3:21 am
    [Douglas Fraze] “what is multiplexing?”
    See the links I provided.
    Cheers
    Eddie
  • Douglas Fraze
    June 1, 2009 at 11:28 pm
    Eddie,
    Problem persists. If I enter Burn DVD or Export to DVD, I get this screen: Export Settings, Format: MPEG DVD; Range: Entire Sequence; Preset: NTSC Progression 4:3 High Quality, 7Mb CBR 1 Pass. Forgot to mention Deinterlace and Scale to Fit are not checked. Export Video and Export Audio are checked. It is set to MPEG-2, and ISO/IEC 13818 in the Multiplex area. Audio: Format – PCM (Dolby Digital, MPEG); Codec – PCM Audio; Basic Audio settings: 16 bit, 48 kHz.
    I went to the FAQ: Why is there no audio in my exported MPEG file? Second bullet said I needed to select “DVD” in my multiplex setting to get audio and video in a single file … I then went to See “MPEG multiplexer preset options” in the Premiere Pro 2.0 Help for details.
    After I went there I did not find a “DVD” to select in the multiplex setting.
    What am I missing?
  • Eddie Lotter
    June 2, 2009 at 1:59 pm
    [Douglas Fraze] “It is set to MPEG-2, and ISO/IEC 13818 in the Multiplex area”
    That sounds correct, according to page 391 of the PPro 2.0 manual.
    Have you tried playing the exported file in multiple different media players?
    Cheers
    Eddie
