Activity Forums Adobe Premiere Pro Audio on imported clip disappears halfway through the clip
  • Audio on imported clip disappears halfway through the clip
    Posted by Bill Celnick on February 26, 2015 at 3:41 pm
    Hi – I’m working on a project in Premiere CC 2014, Mavericks o/s, in which I have imported a 19 minute clip into the timeline. At approximately 7 minutes into the clip the audio disappears, although the video continues.
    The audio is there if I listen to the clip through the Quicktime player, so I’m somewhat baffled by it just dropping out within Premiere.
    The footage is AVCHD (h264) footage recorded by a Sony NX 30, and imported via Media Browser. This is the middle of the project – prior clips in prior sequences played properly.
    I have a feeling this has to do with generating cfa files, so I tried to both re-import the clip, and to start over in a new project, but neither has worked.
    As a work-around I transcoded the clip with Clip-Wrap into ProRes LT – and my sound is there as it should be.
    I’ve been using Premiere Pro as my main editing software for about 6 months (after years of FCP 7), and have not had this before. I recently added the Factory FX plugin which I suspected and have removed, but the problem remains.
    I’m curious if anyone else has had this situation.
    Thanks.
    Bill
    Bill Celnick replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
