Activity Forums Apple Final Cut Pro Audio offset when exporting to Protools
  • Jeremy Garchow
    August 9, 2014 at 2:39 pm
    No, the ignored effects should have no bearing on this.
    I’m not exactly sure where the offset is coming from, I would email x2pro and explain the situation (they also have a support forum).
    Another thing to try would be to stamp tc in the wav files with Wave Agent.
    Be sure to dupe the stems beforehand in case something goes wrong.
    Jeremy
  • Martin Leroy
    August 9, 2014 at 2:47 pm
    I tried the Wave Agent trick and it didn’t change anything.
    Every single audio file I import in FCPx is 60fps!
    Thanks Jeremy!
  • Jeremy Garchow
    August 9, 2014 at 5:19 pm
    I assume you reimported after changing tc?
    Make a new library and reimport there. Any difference?
    How big is the offset?
  • Martin Leroy
    August 9, 2014 at 10:50 pm
    Reimport doesn’t seem to change anything.
    Offset is not too big but quite random.
    Am I the only one having sounds playing at 60fps?
  • Jeremy Garchow
    August 10, 2014 at 12:16 am
    Frame rate, in audio, doesn’t really matter in the sense that it doesn’t dictate much in terms of speed of playback.
    Tc is simply a guide to match to video.
    If the offset is random, something weird is happening in the translation.
    I’d email x2pro.
    Jeremy
  • Charlie Austin
    August 10, 2014 at 6:31 am
    Late to the party but… what’s the frame rate of your FCP X project?
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
Page 2 of 2
