Activity Forums Avid Media Composer audio offline when moving media to different drive
  • audio offline when moving media to different drive
    Posted by Richard Barber on February 27, 2008 at 4:35 am
    I digitized some betacam video onto a portable drive at DV 25 411. I then copied the project onto my mac and successfully played the media in my project on Avid Xpress Pro HD. But this only works when the media is played from the firewire drive. When I copy the media onto one of my internal drives where I store the rest of the media for the hdv project, disconnect the firewire drive and relink the media I can play the video of the DV25 clips, but not the audio, and the bin lists the audio as offline. Yet as far as I can tell the copies of the media files are identical to the originals on the firewire drive. I’d really like to free up the firewire drive. Anyone know what’s going on?
    Richard Barber replied 18 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bouke Vahl
    February 27, 2008 at 1:01 pm
    Perhaps you have both OMF and MXF files.
    Look on the external drive, if there are, copy BOTH OMFI mediafiles and Avid mediafiles.
    hth
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Richard Barber
    February 27, 2008 at 3:14 pm
    You’re right! But I there must be something wrong with the way I’m copying the omf files onto the other drive, because the audio is still offline. I started over again, trashed the copied mxf media files, then copied the mxf files into the folder that contains the rest of my mxf media for the project. Then I copied a folder labelled omfi media files onto the drive placing it in the Avid media folder. Again the clips play the video but not the audio, and the audio is offline. I tried relinking but that didn’t do anything. I wondered if I have to convert the omf files, but I didn’t need to do anything like that to get the audio to play from media on the firewire drive. Can you follow up your first astute diagnosis with another?
  • Rory Brennan
    February 27, 2008 at 3:50 pm
    Perhaps a more thorough option would be to consolidate all the media to your desired drive. Whilst this might take longer, it should grab everything you need without you worrying about missing files.
  • Richard Barber
    February 27, 2008 at 5:48 pm
    Thanks, consolidating did the trick. I really appreciate the quick help, and this site that makes it possible.
  • Richard Barber
    February 27, 2008 at 5:53 pm
    I’m new to these forums and I just tried to rate a post for the first time – yours. For the record: I meant to give your very useful post maximum cows, but I mistakenly gave only one, and the vote apparently cannot be changed.
  • Ben Wilson
    March 5, 2008 at 2:28 pm
    Richard,
    I know you already resolved this, but for future reference:
    The OMFI Media folder must be on the same directory level as the AVID Media folder, not in it. Both must be at the top directory level of the Media Drive. If the OMFI Media Folder is in a subfolder, AVID will not see it.
    Ben Wilson
    Engineering Project Manager
    SCETV
  • Richard Barber
    March 5, 2008 at 3:03 pm
    Thanks.
