Activity Forums DaVinci Resolve Audio not Swapping In Multicam
  • Audio not Swapping In Multicam
    Posted by Kasey Gay on April 19, 2021 at 10:27 pm
    Hey team,
    Just a quick inquiry. I’m just starting to work with Multicam clips in DR, having previously worked in fcpx.
    I have no problem swapping video tracks with ease. Click the correct windows. Angle swaps. A cut happens on the time line.
    I can’t seem to get the same result with the audio though. I select the music note to designate audio swapping. Click the windows, no result. No change in angle. No cut on the timeline. I feel like I’m doing everything right. The audio tracks are in there. I can use Alt + (number key) to swap fully. But I can’t make cuts between audio sources during the edit as different people speak.
    Is this something anyone else has encountered? I can’t figure out if I’m doing something wrong or if this is a software quirk.
    Help?!
    Kasey Gay replied 5 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
