Activity › Forums › Adobe After Effects › Audio not playing
  • Audio not playing
    Posted by Kelly Johnson on June 13, 2005 at 8:07 pm
    I can preview the audio track ( a .wav file) but when I render a movie with the audio enabled, the track isn’t playing.
    It’s just a loop. Are there other settings within After Effects I need to check to ensure audio is played in the final movie?
    Kelly Johnson replied 21 years, 3 months ago 2 Members · 3 Replies
  • John Dickinson
    June 14, 2005 at 12:08 am
    Just to confirm… have you selected the render with audio option in the Output Module section of the Render Queue window?
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Kelly Johnson
    June 14, 2005 at 3:54 am
    Yes. It seems that only mp3 will actually sound with video. I’ve imported aiffs, wav and mp3’s though individually they all seem to sound if saved as a quicktime movie, when I add the video track, nothing but mp3 seems to play.
    I just discovered that this afternoon, but it has to be a glitch or something. Surely AE can use anything it can import?
  • Kelly Johnson
    June 15, 2005 at 1:25 am
    Problem solved. I had the darn ‘mute’ actually turned on! The pop-up tips are misleading. It says “Mute audio (if any)” and since the speaker icon was in full blast, i figured that meant it would be on rather than muted.
    I created animations eith text within AE and imported Static images. The video clips I put in didn’t have any sound, so I imported loops I had in aiff, wav and mp3 formats.
    I have 6.5 pro and I’ve installed FlashMX Professional which allows me to export to the flv format. When I export straight to swf format, all sound works.
    I was using the Render Que extensively and check Audio, 8 bit since this was solely to be played on a computer and that was what was screwing me up.
    However, scrubbing doesn’t seem to work with mp3’s so maybe that’s more nomal.
    I’ve tested quite a few cmops since then and I don’t seem to have any problems with the mp3 format other than the scrubbing preview.
    Anyway, thanks for your responses.
