Activity Forums Adobe After Effects Audio not playing on import from premiere.
  • Audio not playing on import from premiere.
    Posted by Moog Gravett on April 29, 2015 at 11:52 am
    Hi folks,
    I have an issue where I’m copying some video clips from Premiere (latest CC on mac) but when I paste them in to my AE timeline, the audio does not play nor can I see any waveforms on the clips.
    It seems to be only these clips, others work fine, the spec is …
    Apple ProRes 422 HQ
    Moog Gravett replied 11 years, 4 months ago 2 Members · 2 Replies
  • Derek Boettcher
    April 30, 2015 at 2:50 pm
    Hey Moog, I don’t know your level of comfort with adobe products, so I may be saying things you’ve already tried.
    1) Check that if you are importing via dynamic link that the audio and video are linked together. I know I’ll occasionally unlink them for various reasons, just remember to put them back.
    2) Instead of opening a dynamic link, have you tried just selecting, copying, and then pasting into after effects? It’s not the best way, but it works. If that is the way you have been doing it, have you tried a dynamic link or straight up import of the same raw footage into after effects?
    3) in AE have you twirled down enough on your video clip to see the waveform? It isn’t like Premiere where you see it right out of the gate, you have to open several layers before it is there.
    4) how are you checking sound? If you are just hitting space bar for a quick preview, it likely won’t play any sound at all. Try hitting “0” on the number pad for a RAM preview, or hitting the decimal button on the number pad for an audio preview.
    5) Make sure that audio is enabled in your RAM preview panel.
    6) Clean your disk cache to see if that was causing issues.
    Hope that helps.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Moog Gravett
    April 30, 2015 at 3:45 pm
    Hi Derek,
    Thanks for your reply.
    I have actually tried all the things you suggest. I’m using the cmd+c in Ppro cmd+v in AE technique. I’ve also imported the same clips via the standard import too but the audio just isn’t there. (and yes, no waveform on twirl down). other audio previews on other types of clips will play just fine, it’s just these particular ones which leads me to believe it’s possibly a codec thing, but then that’s weird as they work fine in Ppro.
    I appreciate the effort anyway 🙂
