Activity Forums Apple Final Cut Pro Legacy Audio not playing in FCP?
  • Audio not playing in FCP?
    Posted by Adam Heayberd on February 22, 2011 at 5:35 pm
    Okay,
    So ive written in alot today but everyone has been great in helping!
    This time, its the audio. I import the file, which is 48.0khz, 16-bit integer, (and even did one that was 32-bit floating point) and when I put it in the viewer and play it, the audio outputs show the music to be playing but there is no sound.
    The mac is playing sound as when i play the track through quicktime, it works.
    Additionally, i put 10 sec of the music on the sequence and quickly exported it. When I played that export thru QT, the audio was there.
    Have I not got a setting right or something?
    Please help!
    Regards
    Adam
    Editor & Self Shooter in the UK
    Adam Heayberd replied 15 years, 6 months ago 2 Members · 2 Replies
  • Jean-christophe Boulay
    February 22, 2011 at 8:15 pm
    FCP is probably simply outputting through another device or output. Go to your Audio/Video Settings (opt+cmd+Q) and set your Audio Playback to whatever device you are monitoring through.
    IHTH
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Adam Heayberd
    February 22, 2011 at 9:06 pm
    Prior to your kind response I did look in the Audio/Video settings and it was set to ‘Blackmagic’ (which is the software that came with the Decklink…
    I changed that to ‘default’ and et voila….I have sound.
    Thank you very much for that advice!
    Best
    Adam
