Activity › Forums › Adobe Premiere Pro › Audio Not Playing After 2 Minutes?
  • Audio Not Playing After 2 Minutes?
    Posted by George Sims on November 9, 2009 at 5:26 pm
    Hey there Cow guru’s,
    I’m having some audio playback issues.
    When I import an audio track longer than 2minutes (roughly), Ppro doesn’t want to play back the audio. I can see the audio waveform, but the meters don’t register any sound. The track plays just fine in iTunes.
    I also tried cleaning the cache and re-importing the file. Still same glitch at the same point. I can’t say that this always happens, but it’s happened enough for it to necessitate a post.
    Any thoughts?
    -gS
    Jake Williams replied 16 years, 10 months ago 3 Members · 2 Replies
  • Ann Bens
    November 9, 2009 at 11:05 pm
    If an audio track plays in iTunes it does not automaticly means that it will play in Premiere. Could be a codec problem. If you want to be on the save side stick to wave.
  • Jake Williams
    November 11, 2009 at 2:18 pm
    You could try exporting a .wav file using media encoder and re-importing that into file your project.
    Jake Williams
