Activity Forums Apple Final Cut Pro Legacy Audio Noise Reduction
  • Audio Noise Reduction
    Posted by Diego Bonassi on August 20, 2009 at 4:12 pm
    Hi all,
    do you know how i can attenuate a noise reduction on one clip with final cut?
    Is there some plug-in/filter present into the programme or downloadable? or i should pass from sound track?
    many thanks for your time.
    Diego.
    Paul Figgiani replied 17 years ago 3 Members · 5 Replies
  • Jan Bliddal
    August 20, 2009 at 4:44 pm
    I will do it in soundtrack. If you have one of the studio versions with Soundtrack do use that. The way you can lessen noise in soundtrack is way superior to what you can do in Final Cut and it is worth learning. I thing Larry Jordan at https://www.larryjordan.biz has a tutorial that specifically shows you how to do noisereduction, but it is a technique that is taught in a lot of the tutorial I have seen on Soundtrack.
    Let the machine work for you. Not you for the machine
  • Paul Figgiani
    August 20, 2009 at 6:05 pm
    Have a look at this tutorial movie:
    https://www.apple.com/finalcutstudio/soundtrackpro/restoration.html
    Also, I would recommend MR Noise by Wave Arts. It’s an excellent tool for broadband noise reduction.
    https://wavearts.com/products/plugins/mr-noise/
    Either way as noted handling noise reduction in Soundtrack Pro is your best bet.
    -paul.
  • Diego Bonassi
    August 21, 2009 at 7:13 am
    Thanks for your help.
    unfortunatly on my machine I’m having some problem.
    I’m using a G5 2.7 with 4Gb DDR SDRAM
    OS X 10.5.8
    FCP 6.0.6
    STP 2.0.2
    when I switch from FCP to STP for edit audio, all it works. After saving job in STP i don’t see any audio correction in FCP.
    Have I to so something special to save the modification?
    Am I wrong something?
    Many thanks again.
    Regards.
    Diego
  • Jan Bliddal
    August 21, 2009 at 11:21 am
    if you sent your timeline to Soundtrack as individual files not multitrack project you should automatically get your changes in your Final Cut timeline. It does so when I do it.
  • Paul Figgiani
    August 21, 2009 at 1:37 pm
    Jan is correct,
    Here is the deal:
    If you Send to “Soundtrack Pro Audio File Project” the clips open in the STP File Editor. When you save the work, the changes will update in the FCP timeline.
    If you Send to “Soundtrack Pro Multitrack Project” you must export your work (File Menu/Export) and select: After Export – “Send files to FCP Sequence” in the popUp at the bottom of the Export Dialog box.
    You should be all set …
    -paul.
