Activity Forums Audio Audio noise of m4v
  • Audio noise of m4v
    Posted by Stephen Trombley on September 16, 2010 at 8:42 pm
    Hi I have added many (too many to re-edit, 100) of my own video files to a website, having made the error of loading them into editor as m4v, outputting to dv, and back to m4v for website. Of course, they all have audio clicks on them. Is there a way to fix these clicks by passing them through a program with a filter, or do I have to (groan) restart with the original material. Thanks.
    John Fishback
    replied 15 years, 11 months ago
    2 Members · 3 Replies
  • John Fishback
    September 17, 2010 at 7:44 pm
    iZotope RX has a click removal function, but how successfully it works is dependent on many parameters. They have a trial version so you can test to see how it works.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Stephen Trombley
    September 17, 2010 at 7:46 pm
    John, Many thanks, will try it now.
  • John Fishback
    September 17, 2010 at 7:49 pm
    You might also try Bias’ SoundSoap Pro. I use both as sometimes one works better than the other on a particular issue. They, too, have a trial version.
    John
