  • Posted by Aris Gharibain on August 10, 2010 at 5:23 pm
    I just shot a speech over the weekend. The audio I was getting from the board had noise in it. How can I take out the noise with Soundtrack Pro? or is there any better software that can do the job? I’ll appreciate your help in this matter.
    Aris
    Aris Gharibain replied 16 years, 1 month ago 2 Members · 2 Replies
  • Scott Stolzar
    August 10, 2010 at 6:53 pm
    The “reduce noise” process in Soundtrack Pro works pretty well.
    Here’s a basic tutorial:https://www.youtube.com/watch?v=4vyMc5vOh20&feature=related
    You’ll need to play around with the controls a bit in order to get it sounding right. If it’s up too much the noise starts to sound like it’s underwater. If you search the soundtrack pro for reduce noise or even google reduce noise I’m sure you can find more detailed tutorials as well.
    I don’t know about ProTools or any of the other audio programs, but I’m sure someone else can help you out there.
  • Aris Gharibain
    August 10, 2010 at 7:12 pm
    It’s more intermittent noise like a bad audio connector.
