Activity Forums VEGAS Pro Audio no Video on timeline/preview
  • Audio no Video on timeline/preview
    Posted by Neal Evans on November 14, 2011 at 5:46 pm
    I am using sony vegas 10. Here is my problem. When I drag an mpg file into trimmer all is fine. video and audio play OK. When I move this video to the timeline, I get audio and the thumbnails, but no video on the video channel. I am also only able to save this file as a .veg .txt or .aaf. the file’s properties are: MPEG2 29.97 fps interlaced 720x480x32.
    After a lot of searching I can’t seem to find an answer anywhere. Codec? setting?
    Help please
    Neal Evans
    Neal Evans replied 14 years, 9 months ago 3 Members · 4 Replies
  • Danny Hays
    November 15, 2011 at 7:00 am
    If I’m getting you right, You have video playing in the trimmer and the little preview there plays fine. Then you drag it to the timeline and the video clip right ubove it doesn’t play in the thumbmail. Once the video in on the timeline, it’s viewed in the main preview window. If you don’t see it or have accenedtly hid it, select view from the top, Windows layouts and select default layout. You should have your preview window back and that plays video from the timeline. I hope this helps, Danny Hays
  • Neal Evans
    November 15, 2011 at 3:50 pm
    Not quite right. A and V play in the trimmer fine. I drag the clip into the timeline and I get:
    track 1 Video – shows thumbnails
    track 2 audio – audio shows
    Blank video channel – nothing shows
    Master Audio channel – which shows audio levels
    When I play this timeline I hear audio, but no video is displayed in the preview window and I can only save this clip as .veg .txt .aaf.
    I did set the Windows layouts to default layout as suggested with no change.
    Thanks in advance for your help.
    Neal
  • Matt Crowley
    November 15, 2011 at 7:45 pm
    Does this happen for any video or still image file?
    Make sure you haven’t mistakenly muted the video master/output or selected to preview on an external monitor.
    It sounds like you are trying to render out your video by selcting Project > Save As. This will only save the Vegas project, not render out video.
    To render, select Project > Render As, and then you’ll be able to choose from all the usual formats/codecs.
  • Neal Evans
    November 15, 2011 at 9:50 pm
    Ok..I went to project>render as and changed the file format to avi and template over to 1080yuv. The video showed up and played. Now when I import a video it comes up and plays in the preview monitor as it should. I suppose i reset some default setting somehwere when I did the project>render as.
    Consider this problem solved.
    Thank You!
    Neal Evans
