Activity Forums Apple Final Cut Pro Legacy Audio .mov ???
  • Posted by Angela Boyd on April 15, 2005 at 11:02 pm
    I imported two different mov files into FCP. When I play them in FCP there is no audio….but when I open them with quicktime player they have audio. Am I doing something wrong? The audio and video are not seperate. Even when I drag the mov to the timeline it is giving me nothing on the audio tracks of the timeline. Thanks in advance…..
    scottwitt Scott witt replied 21 years, 4 months ago 3 Members · 2 Replies
  • Kevin Monahan
    April 15, 2005 at 11:41 pm
    Angela,
    It’s best not to drag a clip in straight from the Viewer unless you have patch panels for audio and video already set in the Timeline. In fact, dragging and dropping does have a few perils–and you’ve found a good one! That’s why I stick to the standard workflow of always bringing clips into the Viewer FIRST–so I can trim them and set in and outs. When you put clips into the Viewer (as FCP expects), corresponding patch panels show up in the Timeline. If you drag to the Timeline straight away, it will not put the proper patch panels for you to edit there. Makes sense?
    Do this:
    Drag your clip into the Viewer first to get patch panels in the Timeline. Then look to the Timeline to make sure you are patched to A1 and A2.
    Also, connect speakers up out of the DV Deck or DV Camcorder and not the Mac. Your video monitor should be set up out of the DV deck as well.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • scottwitt Scott witt
    April 16, 2005 at 6:08 pm
    from quicktime pro export as .mov
    then export as .aif
    The resync them. I think I have ran into your problem and thats what I did.
