Activity › Forums › Panasonic Cameras › Audio monitoring on the HVX-200
  • Audio monitoring on the HVX-200
    Posted by Matt Steeves on September 8, 2009 at 3:51 pm
    Does anyone know a way to monitor only the XLR audio inputs on the 200? No matter what switches you flick on the camera, it always seems to want to monitor the nat sound mic as well as the XLR inputs. I haven’t seen any posts regarding this issue. You can’t even monitor individual inputs as with the larger (HVX2000) cameras.
    Apple Certified Final Cut Pro 6
    Mac Pro 3.0 Quad
    Kona LHe
    Panasonic HPX-2000
    John Paget replied 17 years ago 2 Members · 1 Reply
  • John Paget
    September 17, 2009 at 10:52 pm
    I have a similar problem. Was shooting today with lav mic input on Channel 1, and camera mic set to channel 2. While shooting, I could hear both mics. On playback from the camera I could only hear Channel 2.
    Switched the lav mic input to Channel 2 just to make sure. Same thing, heard only channel 2.
    After importing the p2 footage, both channels of audio are there and recorded OK – so it is clearly just an issue with monitoring / audio playback from the camera.
    I searched for any settings in the menu which could affect this – could not find. Seems like you cannot even set the audio playback to monitor a particular channel – not an option – you can only listen to both channels I assume (although I cannot hear channel 1 at all – which means it might be broken?). I am sure I used to be able to hear it.
    Strange.
