Activity Forums Audio audio monitor latency – with solution
  • audio monitor latency – with solution
    Posted by Seth Peterson on January 10, 2009 at 6:57 pm
    I’m running a mixpre into a dvx100b and monitouring headphones directly from the camera Headphone output. I’m running a simple 416 and a senhiser wireless lauv.
    I’m a little out of practice with the DVX100b and can’t remember why I have this latency. There isn’t any when I run the internal mics on the DVX. This is my first run with a mixpre. the recordings are in sync.
    Recently running a RED and an FP33 I didn’t have this problem. Its the same with or with out the headphone extension cabl
    Edit:
    Menu- Other functions- H.P. Mode- Tape to Live
    Seth Peterson replied 17 years, 8 months ago 3 Members · 3 Replies
  • John Fishback
    January 10, 2009 at 8:12 pm
    I’m not familiar with the 100B, but other camcorders have a switch that either feeds the mic input or the “tape” output to the headpone jack. If you monitor the “tape” there will be a slight delay compared to the mic in.
    I have a SD302 preamp, but perhaps the Mix-Pre is set up similarly. If you feed the “tape” out from the camera to the monitor in of the pre you can then switch between the mic ins to the pre and the “tape” out of the camcorder.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Ty Ford
    January 10, 2009 at 9:14 pm
    Hello Seth and welcome to the Cow Audio Forum.
    Are you shooting in 24P? I seem to recall that 24P in that camera resulted in monitoring latency.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Seth Peterson
    January 11, 2009 at 3:29 am
    Hey guys thanks for your help. I found it soon after I posted the thread but didn’t see how to delete my post. I added that edit but maybe that wasn’t very clear.
    Thanks for your quick responses. Hard to remember all these different cameras.
