dbFS is just a decibel scale where 0 is considered maximum and infinity considered minimum (Premiere has a fidelity up to -120db).
dbFS is common for digital audio. Older analog recording equipment uses VU or dBu which is almost always a direct voltage measurement of the signal which can go far and well into positive values.
Loudness is perceived as the average level. Your mix shouldn’t peak to far above or valley to far below the spec -16 to -20 range… it’s the “meat” of the signal. RMS, rather than peak, measurement is what you need to look at (broadcast specs get strict with average levels being measured over time with certain frequencies weighted more than others). Premiere VU meter doesn’t give this to you at least not directly. Adobe Audition or any DAW is a better choice for audio mixing. There are plenty of free audio effects that are just volume meters.
The human voice is very dynamic. Depending on the microphones used it does have a tendency to sharply peak. You may want to compress your dialog (this gently squishes the peaks) and raise the overall level. This also makes plosive syllable sounds easier on the listener’s ears.
If you regularly mix audio to specs, consider using Adobe Audition along with Waves broadcast volume monitoring plugin. It’s a setup I’m currently using and I found it totally worth the money.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
