Activity › Forums › Adobe Premiere Pro › audio mixing with keyframes
  • audio mixing with keyframes
    Posted by Sunburntpictures on December 3, 2006 at 9:28 pm
    ok im doing a final mix of my film, and i am having major problems with the audio mixer, i do it live, so when i move the volume it creates keyframes, but thats the problem, it is not creating keyframes as i move the knob, ive tried all the settings, the manual makes no sense. how do i get it to record my keyframes in real time on the audio mixer? i had it working a few days ago so i know it can be done
    please help
    camera lights action
    Mike Velte replied 19 years, 10 months ago 3 Members · 2 Replies
  • Vince Becquiot
    December 4, 2006 at 1:50 am
    I’m not sure if I understand your question, but as long as the stop watch is “selected” on the volume “effect” any changes on the volume slider should result in a new keyframe.
    Vince
  • Mike Velte
    December 4, 2006 at 12:35 pm
    In the Audio Mixer, change the “Automation Mode” from Read to Write for the audio track target. Start playing the timeline and move the slider. Keyframes will be created but not visable unless you change the audio track “Show Keyframes” mode from “Show Clip Keyframes” to “Show Track Keyframes”. This is done at the left end of the audio track in the timeline.
    BEWARE: The keyframes are in the track, not on any clip. In the “Show Track Keyframe” mode you cannot move the audio clips (and linked video) until you switch back to “Show clip keyframes”. If you do move the clips then, all bets are off and you will die a slow death!!
