Activity › Forums › Apple Final Cut Pro Legacy › Audio Mixing Surface for FCP7
Posted by David Page on July 17, 2015 at 7:54 pmCan someone please recommend a moderately priced audio control surface that works well with FCP 7?
Mark Suszko replied 11 years, 2 months ago 5 Members · 6 Replies -
Nick Meyers
July 18, 2015 at 4:52 pmi had a Behringer BCF2000.
very simple, and affordable.i wound up not using it that much.
the plastic faders made horrible clacking sounds when in automation.
check it out here:
https://www.youtube.com/watch?v=HGKiRqJe5pwi wound up using an Alpha-track single fader control surface,
which was great,
i mainly needed to ride levels on music and atmos tracks,
dialogue and spot effects, i use keyboard shortcuts for.i dont think either are available other than on e-bay,
but Behringer does have a nicely priced unit called X-Control compact
touch sensitive faders, which the old one didn’t have
i;d check it out before you buy it though, see if the faders are still just a noisy as the old one.nick
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Warren Eig
July 18, 2015 at 6:22 pmI use the Mackie MCU with extended faders.
https://www.mackie.com/products/mcupro/index.html
It work great and I’ve programmed the job / shuttle wheel and other buttons to mark in/out, play etc.
Warren Eig
O 310-470-0905email: warren@babyboompictures.com
website: https://www.BabyBoomPictures.comREEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories – Monitors and Batteries
website: https://www.EigRig.com -
Shane Ross
July 18, 2015 at 9:42 pmI had a mixer that also did this…forget the model. But didn’t use it also because it was noisy. Fwoosh…swoosh…swish…swush….whoosh… All….THE….TIME.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Nick Meyers
July 19, 2015 at 12:20 amthe Alpha track had a dial to select tracks.
so in a pinch you could almost work 2 tracks at once,but the best thing about that dial was i’d just spin it all the way up to select a track with nothing, or next to nothing on it.
no more shoosh, shoosh
nick
