Activity Forums Adobe Premiere Pro Audio mixing in PPr CS6 Causing Crashes
  • Audio mixing in PPr CS6 Causing Crashes
    Posted by Kenji Ito on November 30, 2012 at 5:18 pm
    Hey guys,
    I have been mixing a 2 hour long conference within Premiere Pro and it’s gotten to the point where it crashes every time.
    First, this is the error i get
    [/Volumes/BuildDisk/builds/slightlybuilt/shared/adobe/MediaCore/AudioRenderer/Make/Mac/../../Src/AudioRender/AudioRenderContextConstructor.cpp-110]
    Since it’s a Multi Camera recording, I am mixing within the Multi-clips. I have a mixture of disabled clips and muted tracks. I put some compressors and limiters on some tracks to change dynamics a little. I’m sure this isn’t proper in the pro audio world, but I’m an Editor. I’m just trying to get the job done.
    Has anyone else encountered this same error before? Any trouble shooting tips?
    I’m running on an early 2012 Macbook Pro 2.4GHz i7 with 8 Gb of RAM.
    Thanks you for your time!
    Michaele de Cygne replied 4 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
  • Phil Lebeau
    November 30, 2012 at 6:31 pm
    Are you using plureyes to line up audio? I have had problems with that software. If not, maybe you can do a mix down of your audio track, without the filters and then add the filters on the new mixdown track. What I mean is, export a new audio file and then relay that file under your video. I am just guessing as to what I would do.
    Phil LeBeau
    http://www.phillebeau.com
  • Petros Kolyvas
    November 30, 2012 at 6:35 pm
    Are you using any plugins?
    We use several plugins (from different vendors) authorized via iLok and Premiere is pretty crash-happy when they’re on the mix buss(es). Without them (or any plugins) it’s far more stable.
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Kenji Ito
    November 30, 2012 at 6:41 pm
    Hey Petros,
    I do have a couple plugins in Premiere but i’m not using them for this project. I will definately keep this in mind though.
  • Kenji Ito
    November 30, 2012 at 6:52 pm
    Hey Phil,
    It worked! I created a mix down, brought it back into PP, than muted all the other tracks and took off the master dynamics. I’m guessing it was just too much stuff going on.
    Thanks so much!
  • Kenji Ito
    November 30, 2012 at 6:53 pm
    Hey Phil,
  • Phil Lebeau
    November 30, 2012 at 7:03 pm
    I’m glad it worked. Someone might have another solution. But at least its working:-)
    Phil LeBeau
  • James Daugherty
    March 25, 2013 at 4:33 pm
    I have a solution.
    Go to Sequence Menu >> Render Audio for Sequence and now it won’t crash.
    Weird…
    James Daugherty
    President SDFCPUG.com
  • Bryan Root
    January 15, 2014 at 10:07 pm
    I am having a similar problem. Getting this error:
    [/Volumes/BuildDisk/builds/MightySilt/shared/adobe/MediaCore/AudioRenderer/Make/Mac/../../Src/AudioRender/AudioRenderContextConstructor.cpp-110]
    I tried all the solutions on this thread and none of them seems to be fixing the problem. I opened up a different project, and that worked fine, so I think it’s something with the project file itself.
    Does anyone have any more suggestions?
    MacPro Mid 2012
    NVIDIA Quadro 4000
    48GB RAM
  • Michaele de Cygne
    November 20, 2021 at 10:31 pm
    This was happening to me. Frustrating. I finally figured it out; I was using the Pitchshifter audio effect on a nested set of clips. PP doesn’t apply that audio effect recursively; when I applied it to the single clip, and simply duplicated it, no problem. Hope that helps someone else.
